Cisco WLC with WAP321 DHCP not working
Marc Aemmer
Since we upgraded our WLC's to Code 8.3.132.0 we are facing issues with our Cisco WAP321. They are configured in Workgroup Bridge Mode and I'm still able to connect to the Web GUI. But the Device connected to the Ethernet Port of the WAP321 is not getting a answer from the DHCP Server. What could be the problem?
thanks,
Marc
 Are you using the same vlan for management and DHCP ? If you put a static IP on the device does it works?
-If I helped you somehow, please, rate it as useful.-
Hi Flavio
Yes, I',m using the same vlan for management and DHCP. If I put a static IP on the device connected to the WAP it works! But before we upgraded our WLC's from 8.2 to 8.3.132.0 it worked fine with DHCP enabled on both the WAP and the Device.
regards,
Marc
