Cisco
Dan Johnson
Visitor
I have a Cisco 5508 controller and am considering using LAG. Can I  enable LAG but only use 2-4 of the 8 available ports on the 5508? Does  anyone see any issues with doing this? I am asking because currently I  don't have enough ports on my 3750G switch to accomidate all 8 ports on  the 5508.
Stephen Rodriguez
that will work just fine.  The WLC will only try to send traffic out of ports that are up.
The only thing you can't do is split the LAG to different non-stacked switches
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Steve is on target ...
Think of LAG like a PORT CHANNEL ..
__________________________________________________________________________________________
