Cisco3850 fuji 16.9 wireless controller configuration
Rosa Ladeira
Because I have being getting many troubles with denalli ios version I have upgraded to fuji 16.9.
Now I can not find commands to configure wireless controller.
Can anyone send me a documentation, please.
Thanks in advance.
Rosa
2 Accepted Solutions
If you need 3850 to run as WLC, then you have to keep it in 16.3.x code & no upgrade possible.
I would suggest to look at alternative solutions (3504/5520 WLCs) & moving away from converged access wireless.
Rasika
*** Pls rate all useful responses ***
Be aware that Cisco has admitted that the implementation of CWA and 3650/3850/Sup8E had some major issues.
Not a lot of people have achieved any successes with this design.
11 Replies 11
balaji.bandi
why you are not considering  :Everest 16.6.x
BB
Rasika Nayanajith
Hi Rosa,
WLC functionality is not supported anything beyond IOS-XE 16.3.x (Denali)
Rasika
@Rasika Nayanajith - you right "Converged access is not supported beyond Cisco IOS XE Denali 16.3.x."
Good to know the information, much helpfull. -
BB
And which is your suggestion to configure wireless controllers on 3850 boxes.
They were bought for this purpose too.
Rasika
Is it possible to transfert AP licences from 3850 to Wireless controller ? (no charge with licensing teams)
It’s different license so the answer would be no.
-Scott
I'm using Denali 16.3.7 with converged wireless setup and it seems to be the most stable Denali release so far. It's also cisco recommended version. Note that converged access is not supported beyond Cisco IOS XE Denali 16.3.x
Hope that helps.
Leo Laohoo
Rasika is correct. CWA is not support after 16.3.X.
