Ciscp AP AIR 1131 with NVRAM Verification Failed
lamrihamza
I have a Cisco AIR 1131 access point(firmware is c1130-rcvk9w8-tar.124-10b.JA3), and when I try to save any configuration, an error message appears: "NVRAM Verification Failed". Please help me fix this error.
Thanks in advance.
Leo Laohoo
The AP is loaded with CAPWAP recovery firmware.
Saving config is not allowed.
thank you for your feedback,
Could you explain further, considering that in my AP the  CAPWAP commands are not supported, whereas those of LWAPP are only accepted
Best regards
LWAPP was the Cisco lightweight protocol used before CAPWAP (so very old and no longer supported).
The recovery image is designed purely to allow the AP to download the correct image from a WLC - it does not support wireless clients and because it is a lightweight image the config can only come from the WLC.
