CleanAir and Spectrum Expert interface protocol?
David Ritter
Level 10
Level 10
Does anyone know what port the NSI traffic is passed on?
Generally I have no issue linking my Spectrum Expert App to my (compatible) AP's.  However, I have one network segment that is full of 2802's and it is not passing NSI data.
 As per Cisco docs:
 "The access point must be a TCP server listening on ports 37540 for 2.4 GHz and 37550 for 5 GHz frequencies. These ports must be opened for the spectrum expert application to connect to the access point using the NSI protocol."
https://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_010001100.html
-If I helped you somehow, please, rate it as useful.-
