cleanAir on AP 2600 FLEX-CONNECT
Augustgood
Hi to all,
My customer wants implement Cisco CleanAir on AP 2600, from on-line documentation "flex-connect compatibility matrix" i found this  "CleanAir (SI on 3500), what does it mean ? It means that it is only supported on ap 3500 and later ?? or the documentation is not updated ?
who can help me?
Scott Fella
SI = Spectrum Intelligence
if the access point is CleanAir 2xxx and 3xxx models, then you can configure CleanAir. The 1xxx models only support CleanAir express and the new 1850 don't support any CleanAir.
http://www.cisco.com/c/en/us/solutions/enterprise-networks/cleanair-technology/index.html
if you are looking at any CleanAir guides, the AP's are pressure much interchangeable for exception that the 3xxx has the ability to add a module to the AP.
-Scott
-Scott
Scott Fella
-Scott
-Scott
