Problem Webauth Cisco 5760
I have a question about webauthentication and redirect.
We use a cisco 5760 controller in our network. At the moment we are implementing a tool which cliënts can install and this tool makes it possible to connect to our wireless network. The cliënts can obtain this tool from an external website. I want to create an open ssid which only allows the clients to get redirected to this website. So when they open a browser they immediately get redirected to this website.
Is it possible to create this with the web policy enabled? Because i have done and tested this, but i doesn't seem to work. First of all i don't get any internet connection, because i am not authenticated. It also doesn't redirect to the website. So is it possible on the 5760 with web policy enabled to get redirected to this website and that i also can make a connection to this website without having to authenticate?
Rasika Nayanajith
Yes, this should be possible.
Here is basic config I have used in  my setup (5760 MC an 3850 MA with guest anchor)
parameter-map type webauth global
 type webauth
 virtual-ip ipv4 192.0.2.1
parameter-map type webauth ABC_Web_Auth
 type webauth
 redirect for-login https://<redirect_URL>;
 redirect portal ipv4 x.x.x.x
wlan ABCGuest 15 ABCGuest
 aaa-override
 band-select
 client vlan X
 ip dhcp required
 mobility anchor
 no security wpa
 no security wpa akm dot1x
 no security wpa wpa2
 no security wpa wpa2 ciphers aes
 no security ft over-the-ds
 security web-auth
 security web-auth authentication-list ABC-GUEST
 security web-auth parameter-map ABC_Web_Auth
 session-timeout 14400
 no shutdown
This doc should also helps
http://www.cisco.com/c/en/us/support/docs/wireless/5700-series-wireless-lan-controllers/117728-configure-wlc-00.html
https://supportforums.cisco.com/document/147091/converged-access-%E2%80%93-local-webauth-local-authentication-and-radius-authentication
Rasika
*** Pls rate all useful responses ***
It is really hard to find a post/document on webauth on 5760 with an external webauth server. The configuration that you have mentioned above, can this be used to do webauth from an external server
redirect portal ipv4 x.x.x.x ! -
I want the users to see the Guest page from the ISE, can I use the above commands to achieve this
Nikhil
