Client cannnot connect to SSID
We have two SSIDs. One of them is connected normally. Another guest SSID cannot connect. Prompt that this network cannot be connected.
The following is the log of debug with a client
WLC:3504
version:8.5.140
AP:2802i
17 Replies 17
Leo Laohoo
@ShengxiangZhang67519 wrote:
*DHCP Socket Task: Jan 06 07:21:54.173: 20:68:9d:86:44:6f DHCP   chaddr: 20:68:9d:86:44:6f
*DHCP Socket Task: Jan 06 07:21:54.173: 20:68:9d:86:44:6f DHCP   ciaddr: 0.0.0.0,  yiaddr: 10.204.20.106
*DHCP Socket Task: Jan 06 07:21:54.173: 20:68:9d:86:44:6f DHCP   siaddr: 0.0.0.0,  giaddr: 0.0.0.0
*DHCP Socket Task: Jan 06 07:21:54.173: 20:68:9d:86:44:6f DHCP   server id: 1.1.1.1  rcvd server id: 10.204.20.254
I can see the wireless client getting a valid IP address, however, gateway IP address is BLANK/missing.
No, the following logs are connected to normal SSID logs. I re-upload a copy
I am not sure if it is because of this bug: CSCvk36887.
I configured:config client deauthenticate ,according to the method of this bug. But still useless
Is that all you can provide?  A debug worth <1 second?
Yes, please don't look at the putty(1).txt file. This is a problem, I will upload a copy again, please take a look.
marce1000
 - Use this tool to have your debugs analyzed , as Leo said the second one is a bit shorthttps://cway.cisco.com/wireless-debug-analyzer/
  Here is the output for your first file which looks normal at first glance :
Connection 1 of 1
TimeTaskTranslated
Jan 06 07:21:53.931 *apfMsConnTask_1 Client made new Association to AP/BSSID BSSID dc:8c:37:86:28:22 AP COFFE
Jan 06 07:21:53.932 *apfMsConnTask_1 The WLC/AP has found from client association request Information Element that claims PMKID Caching support
Jan 06 07:21:53.932 *apfMsConnTask_1 The Reassociation Request from the client comes with 0 PMKID
Jan 06 07:21:53.932 *apfMsConnTask_1 Client is entering the 802.1x or PSK Authentication state
Jan 06 07:21:53.932 *apfMsConnTask_1 Client has successfully cleared AP association phase
Jan 06 07:21:53.932 *apfMsConnTask_1 WLC/AP is sending an Association Response to the client with status code 0 = Successful association
Jan 06 07:21:53.935 *Dot1x_NW_MsgTask_7 Client will be required to Reauthenticate in 1800
seconds
Jan 06 07:21:53.935 *Dot1x_NW_MsgTask_7 WLC/AP is sending EAP-Identity-Request to the client
Jan 06 07:21:53.965 *Dot1x_NW_MsgTask_7 WLC/AP is sending EAP-Identity-Request to the client
Jan 06 07:21:53.988 *Dot1x_NW_MsgTask_7 Client sent EAP-Identity-Response to WLC/AP
Jan 06 07:21:54.112 *Dot1x_NW_MsgTask_7 RADIUS Server permitted access
Jan 06 07:21:54.113 *Dot1x_NW_MsgTask_7 Client will be required to Reauthenticate in 1800
seconds
Jan 06 07:21:54.113 *Dot1x_NW_MsgTask_7 4-Way PTK Handshake, Sending M1
Jan 06 07:21:54.140 *Dot1x_NW_MsgTask_7 4-Way PTK Handshake, Received M2
Jan 06 07:21:54.141 *Dot1x_NW_MsgTask_7 4-Way PTK Handshake, Sending M3
Jan 06 07:21:54.149 *Dot1x_NW_MsgTask_7 4-Way PTK Handshake, Received M4
Jan 06 07:21:54.149 *Dot1x_NW_MsgTask_7 Client has completed PSK Dot1x or WEP authentication phase
Jan 06 07:21:54.150 *Dot1x_NW_MsgTask_7 Client has entered DHCP Required state
Jan 06 07:21:54.170 *dtlArpTask Client has entered RUN state
Jan 06 07:21:54.171 *dtlArpTask Received DHCP ACK, assigning IP Address 10.204.20.106
Jan 06 07:21:54.172 *DHCP Socket Task Received DHCP request from client
Jan 06 07:21:54.172 *DHCP Socket Task Sending DHCP Request to DHCP Server 10.204.20.254 through gateway 10.204.20.1
requesting 10.204.20.106
on VLAN 200
Jan 06 07:21:54.173 *DHCP Socket Task Received DHCP ACK from DHCP server
Kindly raise a TAC Case.
The debug is another <1 second debug output.
What happens if you run this command:
config client deauthenticate 20:68:9d:86:44:6f
I reopened a discussion
After configuring config client deauthenticate 20:68:9d:86:44:6f, there is no effect. The SSID still cannot connect. Tip: Unable to connect to this network
20:68:9d:86:44:6f
What OS is this client running on?  If Android, what exactly is it running on?
Is this happening to one wireless clients or multiple wireless clients?
Can the wireless client(s) authenticate to an SSID with Open authentication &/or PSK?
There are various clients, windows, android, ios, etc.
I have set up open authentication, but I still can’t connect to this network.And there are three or four others who can connect.
