Client Connectivity Problem
Prasan Venky
Level 7
Level 7
Hi All,
We observed all the Nexus 5 model mobiles are not able to connect to Wi-fi network. Any changes on the WLC could help to resolve it ..?
Thanks in advance.
Rasika Nayanajith
Here is the bug ID CSCui87814
Rasika
**** Pls rate all useful responses ****
20 Replies 20
Sandeep Choudhary
Hi, are you using WPA2/Aes or WPA/ Tkip ?
Don't use together .
Its a simple L3 Web authentication.
did you tried this ??
On your device, go to System Settings/Wireless & Networks/Wi-Fi, select the Wi-Fi network that you’re trying to connect to, and tap “Forget.” Then reconnect by selecting that network again and entering whatever password that may be needed.
If still fails then...just paste teh exact error what you are facing ???
Sure. Will try it and let you know.
Rasika Nayanajith
What is the WLC code you are running. Hope it is not 7.5.102.0 code as it had some bug affecting chrome which is the default browser for those android/google phones
Rasika
We recently migrated to 7.5. Could you let me know the Bug id details..?
Hi Prasan,
If I find the bug ID, I will post here. But resolution is listed in bleow posts
1. https://supportforums.cisco.com/thread/2241465
2. https://supportforums.cisco.com/thread/2237455
We had the same problem (Android phones cannot get into guest portal https://x.x.x.x) with our Guest WLAN anchored to a WLC running on 7.5.102.0 code. Fix was the above work around if you want to stick with 7.5.x train.
Rasika
Rasika Nayanajith
Rasika
Many thanks to you for this details. If i wish to upgrade it to 7.6 in my 5508 controller, is it feasible..?
I have 3600 AP's with AC module with Auto-anchor design.
Thanks in advance
Yes it is:
see the comaptibility matrix:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
But I will recommand to go on 7.4 train.
Reagrds
I think 7.4 series code wont support ac module rit... ???
config network secureweb cipher-option rc4-preference enable
Do i have to enable this command on both anchor and foriegn wlc?? and also what is the impact..?
You need to reboot controller to take this effect.
If all your guest traffic is anchored to one controller, this is only required in Anchor Controller.
But those client get IP from any other controller, you have to do this on them as well
Rasika
I executed that command on only anchor (HA configured) controller and found that anchor took longer time than usual in building a mobility again.(More than 5 mins Wifi was down than expected)
I donno why...? Is this command causing this delay ..?
(Note: After executing this command i did not have nexus5 client to test it... will test it and update here soon)
So you have anchor WLC's in HA using AP SSO?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
