Client Connectivity Problem
Prasan Venky
Level 7
Level 7
Hi All,
We observed all the Nexus 5 model mobiles are not able to connect to Wi-fi network. Any changes on the WLC could help to resolve it ..?
Thanks in advance.
20 Replies 20
Yes Mr. scott!!!
Well HA AP SSO wasn't designed for anchor WLC's. This is used for WLC's that have access points joining to them. Redundancy for guest anchoring is done by two licensed WLC with a 12 AP count.
Now I don't think this has anything to do with your issue since you have defined or should I say isolated the issue with a certain device.
-Scott
Thank you Rasika for your wonderful support in resolving this issue
Glad to see it worked for you. Thanks for rating as well
Rasika
Yes right AC module not supported on 7.4, it is only supported on 7.5 and later versions.
If you have 7.5.102.0 on both wlcs then you have to run this command.
Reagrds
Scott Fella
There are open bugs on v7.6 with the 3600's and the 3700's. So your really in a pinch. Your better off staying on v7.5 and adding the command:
config network secureweb cipher-option rc4-preference enable
The open issues with v7.6 is here
https://supportforums.cisco.com/thread/2233768
Your other option is to go with v7.4.121.0 and wait for v7.6 to be fixed, witch will either be a new 7.6.x release of v8.0
-Scott
