Client idle timeout problem
jagebauer
Community Member
Hello to all,
i  have a Problem with a wifi client.
The client login successfully and the 26 seconds later the client recieve an idle timeout from WLC.
*Dot1x_NW_MsgTask_0: Jul 15 12:53:22.471: 00:24:7e:a8:2a:2b x.x.x.x Adding Fast Path rule
type = Airespace AP Client
on AP 00:26:0a:ef:f4:d0, slot 0, interface = 29, QOS = 1
ACL Id = 255, Jumbo Frames = NO
*DHCP Proxy DTL Recv Task:
Jul 15 12:53:23.438
*spamReceiveTask:
Jul 15 12:53:49.622
: 00:24:7e:a8:2a:2b Received Idle-Timeout from AP 00:26:0a:ef:f4:d0, slot 0 for STA 00:24:7e:a8:2a:2b
The idle timeout setting on the WLC is set to 300 seconds! We have no session timeout configured.
We run Software 7.0.98
Has anyone an idea? Ore the same problem solved ?
Thanx for hints .....
: 00:24:7e:a8:2a:2b DHCP server id: x.x.x.x rcvd server id: x.x.x.x
Surendra BG
Guess we are hitting the below bug..
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti91944
Please upgrade the WLC to the latest that we have 7.0.116 and this helps you in getting the issue resolved!!
please dont forget to rate the usefull posts!!
Surendra
Surendra BG
thanx for bug id...
i will upgrade and check if it helps ;.)
Lemme know how it goes.. In the mean time please dont forget to rate the usefull posts!!
Surendra
Surendra BG
