Client roaming issue between APs
abdelouahab.brahim1
Community Member
hello,
I have a wireless network built with Cisco WLC 5520 (in HA), AP 2800. WLC is running code 8.3.133.0.
Randomly, client roaming goes wrong, all I can found in the debug client is this :
xx:xx:xx:xx:xx:xx : MAC of client
yy:yy:yy:yy:yy:yy : BSSID
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-Key from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile xx:xx:xx:xx:xx:xx
*Dot1x_NW_MsgTask_2: Nov 22 09:52:43.707: [PA] xx:xx:xx:xx:xx:xx key Desc Version FT - 0
*Dot1x_NW_MsgTask_2: Nov 22 09:53:52.366: [PA] xx:xx:xx:xx:xx:xx Received EAPOL-key message in invalid state from mobile xx:xx:xx:xx:xx:xx
*apfOpenDtlSocket: Nov 22 09:55:08.983: [PA] xx:xx:xx:xx:xx:xx Recevied management frame REASSOCIATION REQUEST on BSSID yy:yy:yy:yy:yy:yy destination addr yy:yy:yy:yy:yy:y2
Every time it's the same debug, and loss of connection until the client reasscoates with the AP with reassociation request.
As you can see in this debug, about 1 minute and 16 seconde of loss of ping.
We use [WPA2][Auth(802.1X + CCKM)] with a remote radius server (ACS) a cross the WAN.
Any help is much appreciated.
regards,
Brahim,
Rich R
8.3.133.0 is very old and with no software maintenance support - see https://www.cisco.com/c/en/us/products/collateral/wireless/8500-series-wireless-controllers/bulletin-c25-742339.html
If you *must* run 8.3 for some reason then you should be running 8.3.150.x Escalation code which TAC will still support - see https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc11
If you don't have to stay on 8.3 (eg. for very old APs) then you should seriously consider moving to 8.5 or later.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
5 Replies 5
abdelouahab.brahim1
Community Member
hello,
I think somehow the client send eapol pkt with the key version 1 that's ignored by the controller (version 2).
is there a way to ignore the version check in the controller ?
*dot1xSocketTask: Nov 22 09:53:52.365: [PA] xx:xx:xx:xx:xx:xx validating eapol pkt: key version = 2
Thanks in advance,
Rich R
Thank you for your reply, we moved to 8.5.151.0 recommanded by cisco.
We are in observation period.
Any update on this, please?
The upgrade solved the problem.
