Client roaming issues on C9800
Ingénierie RCI
We have a problem with a C9800 Wireless Controller (version 17.9.4a) and Cisco C9120 Access Points. Some clients are roaming from one AP to another, while there're not moving from their desk. For exemple, as shown in the exemple, a client in a meeting room is roaming among 3 AP in a short amount of time :
Even if the latency is high, the client decide to roam without moving.
The access points and the controller are in differents network, the C9800 is running on a virtual machine on Microsoft Azure.
All the AP are in Flexconnect mode, and the policy on the WLAN is only configured in Central Authentication :
We've modified the Data Rate on the RF-Profile, to force Access Point to disassociate clients with a poor rate from an AP, and force them to connect to a closer AP
Do you have any clue about why the client still decide to roam without moving.
I attach the "show-tech-support-wireless" file with the configuration and firmware information
Postscript  : The device shown in the history is a updated Windows 10 Laptop.
9 Replies 9
Mark Elsen
    - Feed your  attachment into : Wireless Config Analyzer
       At least all red errors in the wlc checkresults (html view or excell) should be corrected , but review the other advisories too such as RF related.
     + Client roaming decisions are always autonomous , make sure the layout of the wireless network was done properly with wireless
site survey
    - 17.9.x is becoming gradually EOL , consider moving on to 17.12.3
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
@Ingénierie RCI
 As frustrating as it sounds, this is not a WLC or AP problem. Clients make the call on the roaming not the network.  Update client driver to lasted and check roaming sensibility on the client wireless adapter.
Haydn Andrews
Things like 802.11v and client loadbalancing could do it, however generally find that its related to client drivers or poor RF design
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Leo Laohoo
Is this happening to just one wireless client?
Rich R
Enable Radioactive Trace for an affected MAC address while it roams and then feed the output into the Debug Analyzer (link below) to see how it looks from the WLC point of view.
But as the others have pointed out already, roaming is always a client decision so you need to look at why the client is deciding to roam (all the factors already mentioned by the others).  Start by updating the client drivers to latest version before testing.  For Intel: https://www.intel.com/content/www/us/en/download/19351/intel-wireless-wi-fi-drivers-for-windows-10-and-windows-11.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
atila.kis11
Frequent Visitor
Frequent Visitor
We had the same issue a while ago. Solved this whit changes on the client NIC.
Lowered the Roaming aggressiveness and lowered the TX power. That solved the issue for us.
ammahend
check the log and confirm if you are seeing this CO_CLIENT_DELETE_REASON_DOT11_MAX_STA ?
recently had roaming issue reported, but we were hitting https://bst.cisco.com/quickview/bug/CSCwo37680
had a simple fix and then roaming worked like a charm.
-hope this helps-
Bdas1
Frequent Visitor
Frequent Visitor
What was the fix you made?
aipan-zhao
Frequent Visitor
Frequent Visitor
Regarding this issue, I have encountered a similar problem now. Have you found a solution yet?
