Clients are not connetting wifi on purticular SSID
nidhin.chandran
Hi ,
I have 2X5760 at branch side as foreign controllers and DC having 2X5508  controllers as Anchor. Between Foreign and anchor controllers CAPWAP tunnel is up and running.
I have created new SSIID between these controllers and state(WLAN/Mobility) is up, but branch clients are not getting IP while connecting via new SSID, and getting Network disable because internet connect slow / IP configuration failed error on the mobile devices.
The new SISD and old SSID(working SSID) are using same DHCP pool which i configured on the anchor controllers.
5760 having 3.3.4 version software and 5508 having 7.6.130.0.
can you please suggest what could be the issue.
Nidhin chandran
0 Replies 0
