Clients not associating to APs
CESAR VARGAS
Hello
I have CTVM v8.10.122 and a AP2802E. I have configured a WLAN attached to the management interface, that is untagged (no VLANs in my network).
The issue is that clients cannot connect to the WLAN. In the clients I can see the SSID in the available SSID list, but I always get and invalid password error when I try to connect. I have even tested to configure the WLAN as open (no security) and I get the same error.
Do you know what can be the problem?
I tested the same configuration with CTVM v8.8.130 and it works perfectly.
Sandeep Choudhary
can you run this command "debug clinet <mac address of client>" on WLC and paste the logs here.
Dont forget to rate helpful posts
I have already tried this but no log messages are displayed when I try to stablish the connection.
As you can see, logs are activated:
AP4CE1.75E8.B5FE#sh deb
client:
Client e4:a7:a0:ca:f9:86 debugging enabled for critical, errors, events, info, arp, dhcp, eapol, access-lists
Client Trace Status : Started
Client Trace ALL Clients : disable
Client Trace Address : e4:a7:a0:ca:f9:86
Remote/Dump Client Trace Address : none
Client Trace Filter : auth
Client Trace Filter : assoc
Client Trace Filter : eap
Client Trace Filter : dhcp
Client Trace Filter : dhcpv6
Client Trace Filter : icmp
Client Trace Filter : icmpv6
Client Trace Filter : ndp
Client Trace Filter : arp
Client Trace Output : eventbuf
Client Trace Output : console-log
Client Trace Inline Monitor : disable
Client Trace Inline Monitor pkt-attach : disable
