Clients not receiving DHCP IP address from HREAP centrally Switched Guest SSID
jino_jacob
Hi All,
I am facing a problem in a newly deployed branch site where the Clients are not receiving DHCP IP address from a centrally switched Guest SSID. I see the client status is associated but the policy manager state is in DHCP_REQD.
The dhcp pool is configured on the controller itself. The local guest clients are able to get DHCP and all works fine, the issue is only with the clients in the remote site. The Hreap APs are in connected mode. Could you please suggest what could be the problem. Below is the out of the debug client.
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 Adding mobile on LWAPP AP 3c:ce:73:6d:37:00(1)
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 Reassociation received from mobile on AP 3c:ce:73:6d:37:00
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 START (0) Changing ACL 'Guest-ACL' (ACL ID 0) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1393)
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 Applying site-specific IPv6 override for station 10:40:f3:91:7e:24 - vapId 17, site 'APG-MONZA', interface 'vlan_81'
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 START (0) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1393)
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 Applying IPv6 Interface Policy for station 10:40:f3:91:7e:24 - vlan 81, interface id 13, interface 'vlan_81'
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 Applying site-specific override for station 10:40:f3:91:7e:24 - vapId 17, site 'APG-MONZA', interface 'vlan_81'
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 STA - rates (8): 140 18 152 36 176 72 96 108 0 0 0 0 0 0 0 0
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 START (0) Initializing policy
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state AUTHCHECK (2)
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 AUTHCHECK (2) Change state to L2AUTHCOMPLETE (4) last state L2AUTHCOMPLETE (4)
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 L2AUTHCOMPLETE (4) Plumbed mobile LWAPP rule on AP 3c:ce:73:6d:37:00 vapId 17 apVapId 1
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 0.0.0.0 L2AUTHCOMPLETE (4) Change state to DHCP_REQD (7) last state DHCP_REQD (7)
*apfMsConnTask_3: May 24 13:26:49.372: 10:40:f3:91:7e:24 apfMsAssoStateInc
*apfMsConnTask_3: May 24 13:26:49.373: 10:40:f3:91:7e:24 apfPemAddUser2 (apf_policy.c:222) Changing state for mobile 10:40:f3:91:7e:24 on AP 3c:ce:73:6d:37:00 from Idle to Associated
*apfMsConnTask_3: May 24 13:26:49.373: 10:40:f3:91:7e:24 Scheduling deletion of Mobile Station:  (callerId: 49) in 28800 seconds
*apfMsConnTask_3: May 24 13:26:49.373: 10:40:f3:91:7e:24 Sending Assoc Response to station on BSSID 3c:ce:73:6d:37:00 (status 0) ApVapId 1 Slot 1
*apfMsConnTask_3: May 24 13:26:49.373: 10:40:f3:91:7e:24 apfProcessAssocReq (apf_80211.c:4672) Changing state for mobile 10:40:f3:91:7e:24 on AP 3c:ce:73:6d:37:00 from Associated to Associated
*apfReceiveTask: May 24 13:26:49.373: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) State Update from Mobility-Incomplete to Mobility-Complete, mobility role=Local, client state=APF_MS_STATE_ASSOCIATED
*apfReceiveTask: May 24 13:26:49.373: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) pemAdvanceState2 4183, Adding TMP rule
*apfReceiveTask: May 24 11:35:53.373: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) Adding Fast Path rule
  type = Airespace AP - Learn IP address
  on AP 3c:ce:73:6d:37:00, slot 1, interface = 13, QOS = 3
  ACL Id = 255, Jumbo F
*apfReceiveTask: May 24 13:26:49.373: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  IPv6 Vlan = 81, IPv6 intf id = 13
*apfReceiveTask: May 24 13:26:49.373: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) Successfully plumbed mobile rule (ACL ID 255)
*pemReceiveTask: May 24 13:26:49.373: 10:40:f3:91:7e:24 0.0.0.0 Added NPU entry of type 9, dtlFlags 0x0
*pemReceiveTask: May 24 13:26:49.373: 10:40:f3:91:7e:24 Sent an XID frame
*apfMsConnTask_3: May 24 13:26:49.401: 10:40:f3:91:7e:24 Updating AID for REAP AP Client 3c:ce:73:6d:37:00 - AID ===> 1
*apfReceiveTask: May 24 13:28:49.315: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) DHCP Policy timeout
*apfReceiveTask: May 24 13:28:49.315: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) Pem timed out, Try to delete client in 10 secs.
*apfReceiveTask: May 24 13:28:49.315: 10:40:f3:91:7e:24 Scheduling deletion of Mobile Station:  (callerId: 12) in 10 seconds
*osapiBsnTimer: May 24 13:28:59.315: 10:40:f3:91:7e:24 apfMsExpireCallback (apf_ms.c:599) Expiring Mobile!
*apfReceiveTask: May 24 13:28:59.315: 10:40:f3:91:7e:24 apfMsExpireMobileStation (apf_ms.c:4897) Changing state for mobile 10:40:f3:91:7e:24 on AP 3c:ce:73:6d:37:00 from Associated to Disassociated
*apfReceiveTask: May 24 13:28:59.315: 10:40:f3:91:7e:24 Scheduling deletion of Mobile Station:  (callerId: 45) in 10 seconds
*osapiBsnTimer: May 24 13:29:09.315: 10:40:f3:91:7e:24 apfMsExpireCallback (apf_ms.c:599) Expiring Mobile!
*apfReceiveTask: May 24 13:29:09.316: 10:40:f3:91:7e:24 Sent Deauthenticate to mobile on BSSID 3c:ce:73:6d:37:00 slot 1(caller apf_ms.c:4981)
*apfReceiveTask: May 24 13:29:09.316: 10:40:f3:91:7e:24 apfMsAssoStateDec
*apfReceiveTask: May 24 13:29:09.316: 10:40:f3:91:7e:24 apfMsExpireMobileStation (apf_ms.c:5018) Changing state for mobile 10:40:f3:91:7e:24 on AP 3c:ce:73:6d:37:00 from Disassociated to Idle
*apfReceiveTask: May 24 13:29:09.316: 10:40:f3:91:7e:24 0.0.0.0 DHCP_REQD (7) Deleted mobile LWAPP rule on AP [3c:ce:73:6d:37:00]
*apfReceiveTask: May 24 13:29:09.316: 10:40:f3:91:7e:24 Deleting mobile on AP 3c:ce:73:6d:37:00(1)
*pemReceiveTask: May 24 13:29:09.317: 10:40:f3:91:7e:24 0.0.0.0 Removed NPU entry.
5 Replies 5
Stephen Rodriguez
are you locally or centrally switching the Guest?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Steve,
Thank you for responding. I am centrally switching the guest. But I also noticied a few clients on the locally WLAN stuck at the DHCP_REQD state. It is happening randomly, I reset the APs and all are back to normal. I am monitoring if it happens again.
What is your topology? Do you have an anchor and foreign controller or one controller managing both guest and corporate ssids. Id it is the former, could you paste debug Mobility on the foreign controller.
Saravanan Lakshmanan
#does the client at the remote site roams between AP that connects to different WLC?
#type 9 is not good.
#Does your dhcp server getting hits.
#Also, get debug dhcp message & packet.
#Dhcp server is not responding.
Thank you for your response.
The problem dissappeared after i reset the APs and hasnt returned fortunately. If it happens again I will capture DHCP debugs as well.
