Collision avoidance at probe requests level
mohamedchaaben
Community Member
Do smartphones implement collision avoidance techniques at probe requests level ?
I'm wondering if placing three smartphones together in an isolated room would alter their behavior compared to when they are operating individually (especially in the probe requesting level). I suspect that their behavior might indeed change due to the presence of a collision avoidance mechanism. Do you happen to have any insights on this? Would the timing or content of probe requests be influenced by the presence of other phones nearby?
Thank you!
Rasika Nayanajith
Probing behaviour is depend on each vendor implementation and not listed out in great details in public.
Based on CSMA/CA operation, it is of course make a difference if those phones are in one place (more contention) vs if they are in isolated rooms (less contention, assuming they are not hear each other on same BSS)
Rasika
*** Pls rate all useful responses ***
Rich R
Does this help answer your question?
https://blog.ansi.org/ieee-802-11-collision-avoidance-wireless-networks/
And this has more detail:
https://howiwifi.com/2020/06/30/wireless-contention-mechanisms/
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thank you for your consideration. I already checked those links. They don’t really answer my question. Thanks!
Rasika Nayanajith
Rasika
