Compatibility issues between the 350 wireless bridge and the 3com switches!
eoropeza
It seems there is a problem between the ethernet port of a 350 series wireless bridge and the ethernet port of a 4005 3com switch.
Symptoms:
when you just connect them one to another, they work just fine, but after a while, maybe 4 hours, maybe 1 or 2 days, the ethernet port on the bridge just blocks!... eventhough the link is up, no data passes through. I've been solving this problem, unplugging and plugging again the cable, but it's just a quick solution, cause it happens again after 3 or 4 hrs.
ANY IDEAS!!!???
thanks
jimmy.seah
Could this be a spanning tree problem? I'm not familiar with 3com, but is there anyway to turn off spanning tree for that port?
interconecta
Try to set the Ethernet port in the switch to half duplex and set the speed to 10 Mbps with no autosense, this can be useful.
