Compatibility
sramsey
Community Member
I am currently using a Cisco 5508 WLC running software version 8.5.182.0. Can anyone tell me whether or not the Cisco Excess - AIR-AP1542I-E-K9 is compatible?
balaji.bandi
Suggest to read the release notes :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr8.html
Compatable matrix :
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
BB
 Just make sure the AP is really Mobility Express. If does, you need to convert to capwap in oder to join it to the WLC.
