compatibilty matrex for 9800 wlc
actually we are planning to get new 9800-L , is bellow  access points supported by 9800-L Wireless controller , and if it is supported is there any feature and version  limitation
    • AIR-CAP3602I-E-K9
    • AIR-CAP3702I-E-K9
    • AIR-CAP3602E-E-K9
    • AIR-CAP2602I-E-K9
    • AIR-CAP3502I-E-K9
2 Accepted Solutions
balaji.bandi
check the compatibility matrix - which give you direction what version of code you need to support those AP.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
some products may get in to end of life - so check the EOL statement based on the model and Move to Cat 9K AP in the future to get new features.
BB
Rasika Nayanajith
Out of the model you listed only "AIR-CAP3702I-E-K9" works with 9800 WLC.
Use either 17.9.3 or 17.9.4 code version on your WLC.
Refer compatibility matrix given in Balaji's response.
Rasika
*** Pls rate all useful responses ***
balaji.bandi
BB
Rasika Nayanajith
Rasika
