Flexconnect behavior difference between different models of APs
bob.winslow
Visitor
I am trying to understand why an AIR-CAP2702I-A-K9 remains functional when the VPN tunnel to the WLC is lost but an AIR-CAP3802I-B-K9 does not. They are both connected using Flexconnect to the same CT5508 wireless controller. Both models of APs are in LWAP mode as far as I can tell.
When the connection to the controller is lost, the 2702s appear to still function, but the 3802s appear to go through their association attempt in an endless loop. Any information would be appreciated.
Mark Elsen
 - Post the content of the 'endless loop' (well a part of it...) ; also check if there is anything in the controller logs related to that ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
JPavonM
What do you mean by endless loop? Is it rebooting? Is it trying to stablish CAPWAP tunnel?
In Flex mode, whenever a WAN down is detected, the AP goes into standalone mode, and all clients that are connected are kept and they can still forward traffic (as far as there would be connectivity to the far end), but no new clients are allowed to join (this is obvious as authentication is managed by the WLC).
In the meanwhile, the AP would go through CAPWAP discovery trying to re-stablish connection, and this happen to all Cisco APs in whatever mode they are, and this process is endless until the AP joins the WLC.
Rich R
What version of software are you running on that 5508?
If not already on 8.5.182.11 (link below) then suggest you update and then check behaviour again.
As @JPavonM said continuously searching for a WLC is normal and still continues while the AP is in standalone mode.
The key question is really whether the locally switched, locally authenticated SSIDs continue working?
2702 and 3802 run completely different operating systems (IOS and AP COS) so there are many differences in logs and messages you'll see on the console.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
