Compatible Antenna
mis
Frequent Visitor
Frequent Visitor
can anyone tell me if AIR-ANT2485P-R would be compatible with AIR-AP1020-a-k9.  Just trying to piece some older parts together to make a quick WLAN.
Thanks.
Scott Fella
If the antenna has the right connector and is made for that frequency, you can use it.
Scott Fella
Sent from my iPhone
-Scott
Scott Fella
Scott Fella
Sent from my iPhone
-Scott
Leo Laohoo
Is this right?  A 1020?
If this is correct then yes.  The antenna would be compatible.
