Compatible for AP Aironet 2702E-E-K9
lonton16
Hi, I would like to ask if our current AP Aironet 2702E-E-K9 can work with wifi controller Catalist 9800-40 series?
We intend to upgrade our wifi controller but don't want to waste the old AP.
If not, please recommend me the latest model of wifi controller that support our current AP.
Thanks and best regards!
 It does, with Cisco IOS XE Amsterdam 17.3.x
You can check on the link below.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rich R
But be aware that 17.3.x is the last supported release train for the Wave 1 APs so you'll have to replace them before you can upgrade to anything beyond 17.3.
