Configuring 2504 WLC for LanSchool/AppleTV
gpage
Good Day to All,
Recently my small elementary schools have upgraded to Cisco Air-Cap2600 series AP's and a 2504 WLC. Very much a sweet step up from 10 year old Apple Airport Extremes.
My question is what would be the best pratice to enable Multicast via the GUI for the needs of those platforms and any other future P2P services?
Thanks in advance from a newbie,
GEP
5 Replies 5
paolo bevilacqua
Wrong forum, post in "Wireless". You can move your posting with the Actions panel on the right.
Thanks for the info...
What is the WLC software version running on your 2504 ?
If it is 7.4.x follow the below reference guide
http://www.cisco.com/en/US/docs/wireless/technology/bonjour/Bonjour_Deployment.html
If it is 7.5.x following config guide should help
http://www.cisco.com/en/US/docs/wireless/controller/7.5/config_guide/b_cg75_chapter_01011.html
Rasika
Hi Rasika,
It has 7.5.102.0 onboard for software. Thanks for the quick response to my query.
Gary
No worries, hope it will help you to configure multicast/mDNS on your setup
Pls rate the response if it was useful
Rasika
