Configuring cisco AIR-SAP2602I-E-K9
Create Share
We need to configure cisco AIR-SAP2602I-E-K9 for 2 SSIDs. One Domain Users and another for Guests. Vlans are configured in cisco switch. Vlan1 is for Domain Users and Vlan 23 is for Guests. Can we have a simple configuration example?
Thanks.
Rasika Nayanajith
Here is a sample configuration of Autonomous AP with two vlans (in this example vlan 10 & vlan 20 for two different SSID and vlan 1 - 192.168.1.0/24 is for management). Modify SSID name & passwords accordingly.
hostname AP-01
dot11 ssid <SSID-1>
vlan 10
authentication open
authentication key-management wpa version 2
mbssid guest-mode
wpa-psk ascii <SSID-1_PASSWORD>
dot11 ssid <SSID-2>
vlan 20
authentication open
mbssid guest-mode
wpa-psk ascii <SSID-2_PASSWORD>
interface Dot11Radio0
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 20 mode ciphers aes-ccm
mbssid
ssid <SSID-1>
ssid <SSID-2>
no shut
interface Dot11Radio1
channel width 40-above
mbssid
ssid <SSID-1>
ssid <SSID-2>
no shut
interface Dot11Radio0.10
encapsulation dot1Q 10
bridge-group 10
interface Dot11Radio0.20
encapsulation dot1Q 20
bridge-group 20
encapsulation dot1Q 1 native
bridge-group 1
interface Dot11Radio1.10
bridge-group 10
interface Dot11Radio1.20
bridge-group 20
bridge-group 1
interface GigabitEthernet0.10
bridge-group 10
interface GigabitEthernet0.20
bridge-group 20
bridge-group 1
interface BVI1
ip address 192.168.1.100 255.255.255.0
ip default-gateway 192.168.1.1
Switchport config that connect this AP should similar to below
interface GigabitEthernet1/0/41
Description AP-01
switchport trunk allowed vlan 1,10,20
switchport mode trunk
spanning-tree portfast trunk
Rasika
*** Pls rate all useful responses ***
Thanks.
Just one more thing. When I am connecting to the Guest Network, it is taking time identifying the network name as Guest which is actually defined in the DHCP Server which is our firewall? Is there anything we need to do on the Switch or AP side to make it faster?
Thanks.
I do not think there is any config on AP/switch making the process faster.
Rasika
Yiu could always move the guest dhcp to the inside for testing and see if it improves. If it does then yiu know the fw / dhcp server is the delay.
