connect to air-ap1815i-e-k9 without console cable (UPDATE)
MJ88K
Hi all,
I have the AP mentioned in the title of this post.
Out of the box I could connect with it by just going to it's IP address.
I believe I've updated the firmware but I can't figure out what exact firmware version I've updated it to, it has been a while.
Unfortunately I don't have a console cable at my disposal but I do need to get the AP working somehow.
I have tried a factory reset with the Mode button but that did not did the trick.
The LED is blinking from green to red to amber.
It is just going to be a single AP.
Could someone help me out?
I had the stuff lying around to make a console cable so I can connect with the AP with Putty now.
Rich R
So are you saying your question is resolved now?
Anyway a defaulted AP is always going to be using DHCP so simply connect it to a LAN with DHCP enabled and see what IP address it gets then you know what to connect to - simple!
