11-18-2020 09:29 AM - edited 07-05-2021 12:48 PM
I'm trying to connect 2 Cisco C9800-80 together for HA using Release 17.1. I was wondering If I was able to do the following. My two WLC's are in two different in DC's. I want to be able to use RP and RMI. The RP ports for each WLC would be connected upstream to a VSS using a distinct layer 2 VLAN. Please see my revised picture below.
11-18-2020 09:47 AM
Look at the network diagram, yours looks compatible.
M.
11-25-2020 05:25 PM
If I understand your topology correct, you need to put the Active 9800 in one DC and the standby in different DC
It is supported but it is highly NOT recommended (as in AireOS)
Best practice is to run 17.3.2a (as of now) for the RMI+RP support and to place the two 9800 (Active and Standby) in the same DC
If you have to split them in different DCs then you need to make sure:
1) Maximum RP link latency = 80 ms RTT, minimum bandwidth = 60 Mbps and minimum MTU = 1500
2) L2 connectivity for all VLANs between the two eWLCs (Wireless Management Interface and RMI subnet) and (169.254.x.x RP subnet) and (all other Clients VLANs)
Even with that, you are risking to have many problems, biggest one is the Active/Active scenario so please don’t split the HA SSO 9800 between two DCs, instead put HA SSO pair for each DC and if budget not allow then put the pair in one DC.
