controller 2500
i want to ask if controller 2500 support
 - IPv4 & IPv6 .
-  deliver centralized security policies
- wireless intrusion prevention system (IPS) capabilities
- rogue access point indentification and containment
- RF management,redundancy,QoS,=
- Layer 3 fast secure roaming for WLANs
or i have to go to 5500 ??
6 Replies 6
Leo Laohoo
Duplicate posts.
Go here:  https://supportforums.cisco.com/discussion/12217216/controller-2500
abwahid
Level 9
Level 9
Yes these features are available in 2500 series no need to go for 5500
see below link
http://www.cisco.com/c/en/us/products/collateral/wireless/2500-series-wireless-controllers/data_sheet_c78-645111.html
thanks abwahid , i also want to ask about if AP700 support L3 roaming or i have to go to Ap 1602i  ?
Yes, it will support L3 roaming.
kaaftab
Level 9
Level 9
well 2500 series support your required features but with some limitation i would suggest kindly go through the link i share to get better idea
check the following link for latest feature for 7.6.120 ios for WLC
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn76mr02.html#47548
Features Not Supported on Cisco 2500 Series Controllers
  • Wired guest access
  • Bandwidth contract
  • Service port
  • AppleTalk Bridging
  • Right to Use licensing
  • PMIPv6
  • High Availability (1:1)
  • Multicast-to-unicast
Data Sheet for 2500
and for feature check the link
****************Do rate helpful posts*****************
thanks , i also want to ask about if AP700 support L3 roaming or i have to go to Ap 1602i  ?
