Controller based per AP SSID
adm.mehedi
Greatings to all
I need some help on controller based ap
Example: Suppose we want to install some AP air cap 1700, with 2500 series controller. Every AP should broadcast SSID.
AP 1 SSID: Cisco
AP 2 SSID: Guest (in guest location)
Is it possible on controller.
With Thanks
Mehedi Hasan
d.friday
Level 8
Level 8
Mehedi,
By default all SSID created on the WLC are broadcasted on all APs.  If you want only AP1 to broadcast CISCO then you need to create AP group,  ADD the APs to the AP group and then choose what SSIDs you want to broadcaste
Hi Friday,
can you share any documents or link on AP group or how to configure it.
Yasib Ahmed
Yasib,
I sure can  Here is a link to Cisco's config guide. if you have anymore questions let me know. its a pretty easy setup.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-2/config-guide/b_cg82/b_cg82_chapter_01100001.html
****Please rate if you find the info helpful *******
