Controller doesn't work
DanielRusso
Community Member
I bought last month 2 controllers for a client, both are the same model (Aironet 1830i Access Point) but with different Firmware, the primary has the firmware 8.5.140.0 and the secondary the firmware 8.5.131.0.
The secondary supposedly should work as backup and fail over, but it doesn't get IP address, and if I put the second as primary, all my devices doesn't get an IP. This error is related to the firmware version?
balaji.bandi
we need more information about environment to understand what was the issue, how is this deployed ? autonomous mode or what mode ?
BB
Sandeep Choudhary
I suspect its the issue with Firmware. You must have the smae software version both WLCs.
Dont forget to rate helpful posts
Rich R
If you mean Mobility Express (ME) when you say controller then yes they should be the same version for primary and backup.  And you should take the opportunity to upgrade them both to the latest release eg 8.5.161.0.
But if it's not even getting an IP address then you have a more fundamental problem with configuration preventing it from reaching DHCP.
- Get them both onto the same version - preferably latest.
- Personally I prefer to use static IP for any controller including ME (the AP part can still use DHCP)
- Make sure you have IP connectivity before trying to make anything else work.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
