Controller Reboot
oktavian
Visitor
I just realize that my controller is rebooting, without any notification and log
anybody have same problem?
*capwapHATask: Oct 10 16:37:43.600: %DTLS-3-HANDSHAKE_TIMER_FAILURE: [SS]openssl_dtls.c:2185 Failed to stop DTLS handshake timer for 172.120.7.128:5272. handshake_done:F timer running:T ssl:0x58574f70 con:0x1a44fad0
*nim_t: Oct 10 16:37:34.688: %SIM-3-PORT_UP: sim.c:13902 Physical port 3 is up!.
*cpuAclLogTask: Oct 10 16:37:34.665: %ACL-3-CPU_ACL_LOG_UCAPL_DISABLED: acl.c:1361 UCAPL disabled. CPU ACL hits will not be logged.
*fp_main_task: Oct 10 16:33:43.816: %CNFGR-3-INV_COMP_ID: cnfgr.c:4138 Invalid Component Id : Unrecognized (45) in cfgConfiguratorInit.
*nim_t: Oct 10 16:33:33.278: %SIM-3-PORT_UP: sim.c:13902 Physical port 3 is up!.
note : we use WLC 5508 and OS 8.5.182.7
7 Replies 7
Mark Elsen
 - Consider : https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html  and upgrade  the controller accordingly , if applicable -> check if that can help.
                                 (for 9800 based platforms , use 17.9.4 , if applicable)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
Post the complete output to the following commands:
sh coredump
show coredump summary
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
This is coredump summary from our WLC
(Cisco Controller) >show coredump summary
Core Dump upload is disabled
Core Dump file on flash:
SW Version....................................... N/A
Time Stamp....................................... Fri Aug 27 18:45:29 2021
File Size........................................ 22362674
File Name Suffix................................. NoInfo_1630064729.gz
Data Path Core Dump file on flash:
Is the WLC time set correctly (NTP)?
Is so, then no recent software core dump, so that would suggest a power or hardware issue.
Mark Elsen
                     >... we use WLC 5508 and OS 8.5.182.7
 - Have a try with https://software.cisco.com/download/specialrelease/2702eede2b47a5c3bb40795bbe836af6
 M.
balaji.bandi
check crash files from GUI :
BB
