Controller syslog
Wes Schochet
Level 7
Level 7
I am having some issues with certain clients associating to the wireless network.  I am attempting to get the controller to send debug info to my syslog server, but don't seem to be getting any traffic.
I have the IP address set to my syslog server
Syslog Level is debugging
Syslog Facility is syslog  (I have to admit that I really don't know what this field does - I find it confusing)
I have two controllers set like this with about 500 clients between them.  I think I should be getting some information, but don't see anything at all!
Rasika Nayanajith
Hi Wes
What debug commands are you running on the WLC ?
To get debug output send to syslog from WLC, first you have to log onto a WLC CLI, & then issue required debug commands (like debug client ). So whatever the output you would see will send to syslog server as long as you configure syslog level debugging.
You cannot run debug commands permenantly (or without active login session to WLC CLI). Refer below post which will discuss a similar topic
https://supportforums.cisco.com/thread/2242457
Rasika
**** Pls rate all useful responses ****
I didn't realize - that's a bummer.   Is there any way I can browse through recent connection events on a controller?
In GUI, you can goto  Management ->Logs -> Message logs
In CLI, Show Logging
Rasika
