Controller to Manage Branches
thulani@mwgbs.co.za
Frequent Visitor
Frequent Visitor
Hi, Is it possible to deploy one controller for a company that has branches? Deploy it at the head Office provision the AP's then place those AP's at branches but manage them using one controller at the head office? If yes what should be configured?
2 Accepted Solutions
balaji.bandi
Yes Possible, as long as you L2/L3 stretched to Branch offices.
BB
BB
Scott Fella
If the design is for a centrally managed Cisco controller, then like what the others mentioned is yes. You can run local mode for the headend office and FlexConnect local switching for the remote branch.  FlexConnect is the preferred method for the branch unless you have larger circuits where you can tunnel all traffic back to the headend office.
-Scott
balaji.bandi
BB
BB
For sure that works. Have a look at the following document:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/ch7_HREA.pdf
Be prepared to invest some time in learning the basics of Cisco Controller based wireless. It can be quite complex.
If you want to have it much easier, have a look at the Cisco Meraki APs: https://meraki.cisco.com/products/wireless
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Scott Fella
-Scott
