Controller WLC-9800 filter by Device-Type
Claudio Battan
I have already activated user profiling and I see the Device Type.
Does anyone know if it is possible to block access to a certain WLAN based on device-type?
I have a WLAN where only Smartphones (Android or iPhone) should be able to connect.
@Claudio Battan
 How devices are authenticated? PSK or Radius?
PSK
As far as I know it is not possible to block device using profiling . The only way I know is using mac filter, which can be challange.
If you had Radius, this could be done easily on the radius side.
