1920 boot issue
Mariusz00001
Level 2
Level 2
The AP boots up - I connect a console cable and I can see the logo of u-boot and then weird characters. Image broken? That was running an EWC image without problems, rebooted it one day and that's it...
What's interesting, I can see (using CDP) that after a bootup, AP gets an IP from a DHCP server but I cannot ssh/hthtps to it and it is not broadcasting any SSIDs, no provisioning SSID, either.
I tried to get into the recovery mode. I rebooted the AP, u-boot logo appears, I press ESC - nothing happens. Tested on two PCs with putty and securecrt. Any ideas what to do next?
@Mariusz00001
Make sure the console is using baudrate of 115200 bps
Leo Laohoo
If the AP is booting into 17.12.X (and later), change the baud rate to 115200.
Rich R
This has been discussed twice on other threads in the last few days (and many before that)!  Please search for existing posts before asking the same question again.
https://community.cisco.com/t5/wireless/9120axe-console-give-me-only-symbols-after-a-reboot/m-p/5211711#M276769
https://community.cisco.com/t5/wireless/cisco-access-point-9130axe-cli-unusual-language/m-p/5211688#M276766
FYI: this change was introduced by https://bst.cisco.com/bugsearch/bug/CSCwe88390
This is documented in https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/technical-reference/c9800-best-practices.html#AccessPointConsoleBaudRate so it's a good idea to go through that Best Practices guide.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
