02-06-2004 10:14 AM - edited 07-04-2021 09:20 AM
The job runs upto 50 percent and status is 'waiting for confirmation' Log also recieved an error 'uploading the .ini file.
02-06-2004 12:15 PM
Are you using the right IOS Image. You have to also have to create a non-ios template to apply.
02-18-2004 06:04 PM
50% means the image has successfuly been converted. WLSE simply waits for the AP to reboot.
For some reason, AP did not reboot. Try power cycle the AP and it should come back fine.
02-18-2004 06:12 PM
Click on the Refresh icon in the Job Run Detail->Job Run Log to update the screen and see exactly whether the job has completed or failed. Conversion Job takes a while than normal to complete, so you may have to wait to check the status
