Convert Wireless Access Point (AP-1240AG) from Autonomous to Lightweight Mode
itsupport
Hi there
Can anyone tell me how I may go about getting hold of the file "c1240-rcvk9w8-tar.124-21a.JA2.tar" in order to convert an Wireless Access Point from Autonomous to Lightweight Mode. (An AP-1240AG).
My device is new and the details are:
Part: Cisco AIR-AP1242AG-E-K9
Serial number: FCZ144582Y1
MAC: 588D098E63A6
Please could you let me know how I may go about obtaining this software for my Wireless Access Point so I can use it !!!!!!?????
Thanks in advance.
IT Supoort
Surendra BG
I guess you need assistance in gettting the image downloaded.. here is the link to get the software.. you ned to provide your CCO id and password to download the software..
http://www.cisco.com/cisco/software/release.html?mdfid=280237322&flowid=7588&softwareid=280775090&release=12.4%2821a%29JA2&rellifecycle=&relind=AVAILABLE&reltype=latest
If you dont have the software download lisence, then if the device is under warranty please open up a case with TAC and we will help you in publishing the software for you!!
lemme know if this answered your question..
Surendra
Please dont forget to rate the posts which answered your question and mark it as answered or was helpfull
Surendra BG
Hi Surendra
When I enter my CCO id and password to download the software I get told that "To Download this software, you must have a valid Technical Support Services Agreement associated to your Cisco.com user ID."
Whats that all about?
Kind regards
Ian Smith IT Support
Guess, you do not have the software download lisence.. No problem, if the device is under warranty please open up a TAC case and we will help you in publishing the image..
Surendra
Surendra BG
I just checked in my database and came to know that your device is under warranty till 10-FEB-2012, so it will be great if you could open up a TAC case with us right away and your issue will be resolved by End Of the Business Day
To open up a TAC case use the the below mentioned TOLL FREE numbers..
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
Surendra
Surendra BG
