CONVERTING AP2602E TO AUTONOMUS
Kevin100
Hai
i want to convert cisco 2602e to autonomous mode.I tried using mode butting manuely using extracting archive.no success.
could you please tell me which ios and ways to do that.Access point console says timeout,tftp i can see could not find file.
i used these ios  for all process           ap3g2-k9w7-tar.153-3.JAB  , ap3g2-k9w7-tar.default
best regards
john
Leo Laohoo
Error message means the AP can't connect to the TFTP server.  Could be an IP address/subnet mask issue or firewall.
Hai thanks for reply,i can see on tftp log its contacting but it says could not find file spcified this is while using mode button.which ios for conversion ,i use autonomous ios ,is it ok or any recovery one and rename
