06-13-2024 03:35 AM
Hello
I face this issue that is indicated as not reproductible.
What can I do to help ?
Joel
Solved! Go to Solution.
06-17-2024 08:10 AM
Just replied with config guide links but one thing in the 17.9 guide caught my attention:
- While configuring WLAN ensure that the PSK length must be minimum of 15 characters. If not, the APs will not be able to join the controller after changing tags.
Don't suppose you had any WLANs with PSK < 15 characters when you enabled FIPS?
06-14-2024 04:38 AM
      - Ref : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx84736
         Workaround: None at the moment. To rejoin APs FIPS needs to be disabled on controller side.
M.
06-16-2024 05:05 PM
What version of software are you running?
06-17-2024 12:11 AM
@Mark Elsen this is not acceptable solution, I need FIPS to be enabled!
@Rich R software version is 17.03.08a.
Thanks for the help on this.
Joel
06-17-2024 03:36 AM
IOS-XE 17.3 is effectively end of life: https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-xe-17/ios-xe-17-3-x-eol.html and had a lot of issues!
It has already long passed the End of Vulnerability/Security Support date September 30, 2023!
This means that even if you find it's a bug it will never be fixed in 17.3.
There have been hundreds (maybe thousands) of bug fixes since then!
Refer to the TAC recommended codes link below - you should be running at least 17.9.5 or 17.12.3 now.
06-17-2024 12:12 AM
Note: I can provide logs or anything else so that I can maybe help on solving this issue CSCvx84736
06-17-2024 01:30 AM
                              >.. .I need FIPS to be enabled!
                              >... I can provide logs or anything
  - The bug  (https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvx84736 ) report is rather clear :
                >...Workaround: None at the moment. To rejoin APs FIPS needs to be disabled on controller side.
- That means that if this is a strong business concern for you ; then you need to contact Cisco (TAC)
M.
06-17-2024 03:39 AM
No new bugs will be investigated or fixed in 17.3 code now.
If you want to pursue a fix then first upgrade to a currently supported release like 17.9.5 or 17.12.3 and then if you still see the issue open a TAC case for Cisco to investigate further.
06-17-2024 05:09 AM
Ok, thanks I understand. This is a real issue since the FIPS approval from the NIST is only valid on 17.3, except if you indicate me a newer version is FIPS validated ? I have C9120AXE hardware.
06-17-2024 06:42 AM
It looks to me like FIPS is certified in 17.6 and 17.9. All certificate details at https://www.cisco.com/c/en/us/solutions/industries/government/global-government-certifications/fips-140.html There we see:
| Embedded Wireless Controllers on C9100 AP IOS XE 17.9 | 2022-08-01 |
17.12 is certified on regular 9800 series WLCs:
| Cisco C9800 Wireless Controllers IOS XE 17.12 | 2023-11-23 |
and 17.12 on 9100 series APs:
| Catalyst 9100, Wave 2 and IoT Wireless Access Point IOS XE 17.12 | 2024-03-06 |
So as far as I can see you could move to 17.9.5 straight away and I suggest you fire off a query to certteam@cisco.com about EWC on 17.12 in preparation for the fact that 17.12 will soon become the recommended release train. You can also ask why NIST only lists 17.3.
Also see: https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2024/pdf/BRKEWN-2339.pdf page 14:
06-17-2024 07:35 AM
@Rich R thanks so much for this details, this is good news for me.
I will move to 17.9.5 as you suggested.
Latest question on this topic please: I previously asked for a good guide to enable FIPS on the AP but didn't get any answer: https://community.cisco.com/t5/cisco-software-discussions/activation-of-fips-mode-on-c9120ax-access-point/td-p/5106171
Can you indicate a good reference ?
06-17-2024 08:10 AM
06-17-2024 08:21 AM
Thanks a lot @Rich R !! Got the link to the documentation
The PSK was less than 15 characters
So probably this is the origin of the issue.
I will reset the AP now. You can consider this ticket solved and closed.
Again thanks for your support.
Joel
