Access point doesn't join the controller
shamik
Visitor
After resetting the Access point AIR-CAP1602E-E-K9
It doesn't join the controller Cisco 2500
These are the logs from Console of the AP
*May 30 10:03:21.999: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*May 30 10:02:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 172.16.10.50 peer_port: 5246
*May 30 10:02:17.275: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from 172.16.10.50
*May 30 10:02:17.275: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*May 30 10:02:17.275: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 172.16.10.50:5246
*May 30 10:02:17.275: %CAPWAP-3-ERRORLOG: Invalid event 40 & state 3 combination.
5 Replies 5
Rich R
Upgrade the controller to 8.5.182.11 software (link below) and follow the procedures detailed in the field notices which Leo linked and below in my signature.
The first thing you'll have to do is disable NTP and set the date back to before the certificate(s) expired (could be AP and WLC certs expired) - that will let the AP join again.  Then upgrade the software and apply the additional config to WLC from (config ap cert-expiry-ignore mic enable).  Once WLC and AP software have been upgraded and new config applied to WLC and updated to AP then you can re-enable NTP.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
shamik
Visitor
I cannot upgrade my cisco WLC 2500 which is running 8.2.100.0, as I don't have any support contract active.
And I have 46 AP's currently working which is connected to the WLC,
AP Models connected are - AIR-CAP1602E-E-K9, AIR-AP1852I-E-K9, AIR-AP1852E-E-K9
         >...I cannot upgrade my cisco WLC 2500 which is running 8.2.100.0, as I don't have any support contract active.
  - Then the only thing you can do is disable NTP and set the controller time  backwards.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Find a recent security advisory that affects 8.5 code and find the section which says "Customers without Contracts" then email TAC (don't phone). You must quote the URL of the advisory, the paragraph just mentioned and the version and URL https://software.cisco.com/download/specialrelease/9a6a7cf84f9fdf04b95c76e2ac7820e7 for the software you want to download and the serial number of your WLC.  You'll have to mention which platform you need it for (2504) because they have all of them there at that URL.  Then TAC should publish the software to you directly.
This advisory should be suitable: Cisco Wireless LAN Controller AireOS Software FIPS Mode Denial of Service Vulnerability because CSCwa40778 : Bug Search Tool (cisco.com) is fixed in 8.5.182.12. (even though the advisory itself says upgrade to 8.10)
"Customers Without Service Contracts
Customers who purchase directly from Cisco but do not hold a Cisco service contract and customers who make purchases through third-party vendors but are unsuccessful in obtaining fixed software through their point of sale should obtain upgrades by contacting the Cisco TAC: https://www.cisco.com/c/en/us/support/web/tsd-cisco-worldwide-contacts.html
Customers should have the product serial number available and be prepared to provide the URL of this advisory as evidence of entitlement to a free upgrade."
