CT5508 wlc and Lost wan connections and remote AP case
sertorivs
Hi Team
I have an urgent question , my customer wants buy a couple of CT5508 in HA Cluster in Central Site, t he rest of remote sites would have controlled Aps
The question is In the case of lost connectivity wan lines, What´s the end users issue?
I mean, end users will be supported by wireless services locally by remote APs or not? new end users would attach to APs or not?
Regards.
Sandeep Choudhary
Hi..You can use HREAP/Flexconnect Solution
In this method there is a mode in whihc you can use local switching(mean once you lost the connection from Centrel site your remote AP will still provide the Wireless access and they will mapped to local vlans)
Check this docs:
H-Reap Design and Deployment Guide
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/71250-h-reap-design-deploy.html
H-REAP Modes of Operation Configuration Example
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/81680-hreap-modes.html
Don't forget to rate helpful posts
Ok thanks
and in this case too:
Lost the wan connection using the H-Reap but the remote access point is reloaded  by electric power issue
What´ll happen it?
Depends which mode you configured:
  • Central Authentication, Central Switching
  • Central Authentication, Local Switching
  • Authentication Down, Local Switching
  • Local Authentication, Local Switching
  • Authentication Down, Switching Down
Yes it can provide the connection even in the case of reboot.
Just read once these types of mode: http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/81680-hreap-modes.html#cl
