Current Office Extend APs
Johnny5Alive
Frequent Visitor
Frequent Visitor
Will someone please confirm which current APs can be configured as Office Extend devices?
jagan.chowdam
 Which Catalyst 9100 access points can be teleworker/Office Extend Access Point (OEAP) enabled?
A.    All of the Catalyst 9100 access points (as well as all of the Aironet access points) can be outfitted to support a teleworking initiative. With an OEAP, an employee at home or in a temporary micro-office will have access to the corporate SSID and the corporate network without any advanced technical know-how or the need to set up a VPN. Furthermore, any Cisco controller—virtual or physical—can be used for creating the secure tunnel from your employee’s home to your office.
Jagan Chowdam
/**Pls rate useful responses**/
Rich R
> "All of the Catalyst 9100 access points...can be outfitted to support a teleworking initiative"
There is an exception in the current 9100 range - the CW9163E.
There are also some exceptions for AireOS (you did not mention the WLC model and software version).
Refer to:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc118737963
and
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc118737969
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
