Custom Web Auth not working
srosenthal
Level 8
Level 8
I am trying to load a custom web auth bundle for passthrough on a guest SSID and I modified the html files in the bundle that I downloaded from Cisco and then uploaded them succesfully into the 5508 controller.  However when I attempt to preview the page it fails to load.
I created a tar file using 7-zip and just included the two html files and the logo.
I am attaching the files I used for reference.
Thank you.
Hello Scott.
Thank you.
You are right. There is a limit for the tar file size which is 1 MB.
But I can also see the tar file attached (the logo image is included in the tar file) while the size is about 629 KB.
I think that can eliminate the file size. right? what do you think?
Amjad
Rating useful replies is more useful than saying "Thank you"
Amjad Abdullah
You need to make sure you don't face any of the limitations that are available for the tar file.
look here: http://goo.gl/VkIzDL.
If everything is OK try then to change the program you used to make the tar file. the link above suggests PicoZip.
Amjad
Scott Fella
You need to reduce your logo resolution. This is putting your tar file size over the limit. If you look at the link Amjad posted, you will see the recommended file size.
-Scott
Hello Scott.
Thank you.
Amjad
It is now working.  It turns out it had to do with the way I was accessing the equipment.  I was using remote access to a computer in my lab and today I went to the lab and attached my computer directly and it worked.
The weird thing is the Cisco default splash page works remotely but not the custom page.
Either way it works properly and I kept the image at the original size and used 7-zip.
Thank you all for your help.
Seth
