Customer 1400 Power injector stolen
RaveDave1
I have a customer with a 1400 link that had the indoor power injector and power supply stolen.
I am ordering the AIR-PWRINJ-BLR1=. Does this come with both the power injector and power supply?
If it doesn't come with the power supply what can I order that will work with the power injector?
Rob Huffman
Hey RaveDave,
That is a great question! We do not use the 1400's, so I tried to find this info on the Cisco site (good luck!!).I think you should order the following part:
AIR-PWR1400=
Which is the power module for the 1400. This is about a $50-60 US part so I don't think you can go too wrong.Here is one of the links that shows these as 2 separate items for ordering.
http://perksystems.com/aironet1400.htm
Hope this helps!
Rob
Please remember to rate helpful posts .....
Thanks for the info. Added it to the order for my customer.
Cisco's web site has almost no info on this. I searched for over 2 hours yesterday, trying to see if there was some combination of search parameters that would give me the info or if there was a 1400 document that would help. No luck.
Rob Huffman
Hi RaveDave,
You are not kidding! I have trouble finding info on the site as well. It is like an art trying to manouver your way around.Let us know when your equipment comes in and you have evrything back up and running,whether this was indeed the right part. Just for future reference.
Take care!
Rob
