Customize features in WLC
prashanma
Level 4
Level 4
Hi Team
I want to build following to my system. I already have WLC3504 and 5 1832i access point
Pre-built templates for Wi-Fi guest portals
Drag-and-drop components to create a custom portal pages
Multiple access methodologies (SMS, guest vouchers, email authentication, social media login)
Guest user analytics (new vs. repeat visitors, network usage, portal and SMS success ratio)
What are components that I need to use to achieve above ? Do WLC3504 already exits above (I couldn't find any information in datasheet) features ?
7 Replies 7
you need to integrate cisco ISE to do this requirement. check below link.
https://www.cisco.com/c/en/us/products/collateral/security/identity-services-engine/data_sheet_c78-656174.html
*** Pls rate all useful responses ***
Good Luck
Good luck
KB
Thank you Kasun
please mark as a solution, if so..
thank you
Good luck
KB
Cisco ISE Express - ISE Express, is a comprehensive licensing bundle that offers enterprise-level guest services, including hotspot, sponsored, and self-registration portals. It also provides RADIUS authentication, authorization, and accounting (AAA) for the endpoints.
The bundle includes Cisco Identity Services Engine Base licensing for 150 endpoints, an ISE virtual machine, unlimited access to the ISE Portal Builder, a web-based portal customization tool, and a quick installation guide.
https://www.cisco.com/c/en/us/products/security/identity-services-engine-express/index.html
Check the comparison table in the above link.
Hope this helps
Jagan
Hi All,
Apart from Cisco ISE, can't we use CMX. ?
Because I don't find drag and drop for customize portal in ISE. So what will be best match for above requirement ?
https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/connected-mobile-experiences/datasheet-c78-734648.html
in ISE you can create BYOD portals, Policies and stuff easily. you can check below link for some explanation of ISE config related to Wireless.
https://www.youtube.com/watch?v=HH_Xasqd9k4
im not sure about CMX. its better select product according to your preference. 🙂
Good luck
KB
