CW9166I Access Point Temperature periodic monitoring.
madhurimuppalla
We have a setup of CW9166I Access Point  connected to  C9800-CL vWLC.
We are able to check the temperature of the Access point using the below CLI command,
AP149F.430E.DC80#show thermal-control-summary
CPU temperature                 = 56 C
Remote sensor temperature = 50 C
But, the temperature need to be periodically checked, so is there any Tool or Application to monitor the Access Point Internal temperature periodically?
Leo Laohoo
Yes and no.
Yes, DNA Spaces can "monitor" the temperature.  As to doing it using SNMP or API, I am not sure.
In CLI, it can be scripted using following WLC commands:
Temperature &/or Humidity
test platform software database get ewlc_oper/ap_temp;ap_mac=<AP ETH MAC ADDRESS>
Air Quality
test platform software database get ewlc_oper/ap_air_quality;ap_mac=<AP ETH MAC ADDRESS>
Take note of CSCwh60483 & CSCwk74648.
