CWWLSE
azmath.hk
Level 5
Level 5
Dear all,
First time I'm going to install CWWLSE 2.9, I connect monitor,Keyboard and mouse to it and now its asking username and password but I dont know which username and password should I supply in order to login..Basically If you guys provide me the configuration guide and default username and password of this deivce where I can find proper information and able to configure and run the device...
Your true assitance will be highly appreciated.
Azmath Khan.
rmushtaq
Level 11
Level 11
There is no default username/password. When you configure the box for the very first time, you login as user 'setup' with no password and then during the config, you select the login that you want to use later. See: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cwparent/cw_1105/wlse/2_11/1130_igd/1130cfg.htm for details.
Mushtaq,
Thank you very much for your excellent support.
Azmath Khan.
