Data Rate Setting for subset of access points
lincolnwebber
Is there a way I can select a subset of the access point on  controller, group them and apply data rate configuration to the group.
I have a building with multiple floors. I want to use a single floor as a test bed for disabling some low data rates in order to alleviate some co-channel interference. Test for a few days and roll the change out the other floors.
Is there a way this can be achieved?
I'm using 5500 series WLCs runninf 7.6, Cisco Prime 2.0 and a mix  of 3500 and 3700 APs.
Rasika Nayanajith
Yes, you can use RF profile configuration for this. See below
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-0/configuration-guide/b_cg80/b_cg80_chapter_01011101.html
Rasika
*** Pls rate all useful responses ***
