Default login for air-ap2802-e
eddie.sardinha
What is the default login for an air-ap2802-e?  I've already tried Cisco/Cisco, admin/cisco, cisco/Cisco!
In addition are there any good configuration guides? I coudn't find any detailed enough.
Tori_Ok.
Could you clarify what login interface you are referring to (Telnet/SSH/Mobility Express).
I didn't need a default login for the AIR-AP2802I-A-K9. During Mobility Express setup (https or CLI), I created an admin username and password. That's the same credential I use for SSH access to any AP added to the network.
Sounds like you're performing a new deployment. I'd suggest you use the reset button and go through the setup process to create the login creds.
diomarga
Try with admin/admin for first time SSH login if the AP is in Mobility Express mode.
DiamanteDesk
I tried by cable console Cisco/Cisco and worked,
