ā10-17-2012 01:59 AM - edited ā07-03-2021 10:51 PM
I have a Cisco Wlc 4402 , denon 3312 & AP 1142 all three devices are same subnet . But Airpaly not showing in Iphone. But if i put a Airport express in on these subnet then i find airplay option. Give me some idea how without Airport express i can enable airplay....
Solved! Go to Solution.
ā10-17-2012 03:36 AM
You do need to configure certain things when you use a WLC. Other devices like airport and home routers work fine, but not the WLC's and bonjour.
There are a couple ways to do this. Since everything g is on the same subnet, you need to enable multicast on the WLC and on the switch/router. Here is a doc for this
https://supportforums.cisco.com/docs/DOC-24187
If you were to put devices on different subnets, then you need a bonjour gateway. Here is a doc for that
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_tech_note09186a0080bb1d7c.shtml
ā10-17-2012 03:58 AM
As quick test skip wired piece, keep all intended devices on WLAN mapped to management vlan of wlc, enable multicast on wlc.
